Denray Posted July 19, 2017 Report Posted July 19, 2017 Two areas where 16 feet or so of sill plate is missing. Is that a problem?
John Kogel Posted July 19, 2017 Report Posted July 19, 2017 I don't want to stir up a nest of snakes for your clients, but, ..... I would want the house anchored to the foundation in your part of the continent. They will need anchor bolts to get earthquake insurance, and no sill means probably no bolts.
Denray Posted July 19, 2017 Author Report Posted July 19, 2017 There is that. Lots of sill elsewhere. Thanks John!
Marc Posted July 20, 2017 Report Posted July 20, 2017 Looks like the house is elevated off of the foundation for some reason. If you do that, you need to provide both vertical support and shear strength in that space between foundation and structural floor. The posts might be ok to provide the necessary vertical support if they were secured to a treated sill plate below and to the structural floor above but where's the shear strength coming from? I don't see any.
Mike Lamb Posted July 20, 2017 Report Posted July 20, 2017 12 hours ago, John Kogel said: I would want the house anchored to the foundation in your part of the continent. What part of the continent is that? Denray, you should update your location.
Mike Lamb Posted July 20, 2017 Report Posted July 20, 2017 A lot of folks should update their location.
