Denray Posted April 27, 2017 Report Share Posted April 27, 2017 Light in shower of old viki has metal ring around it. My voltage sniffer goes off whether the switch is on or off. How serious is that? Link to comment Share on other sites More sharing options...
Marc Posted April 27, 2017 Report Share Posted April 27, 2017 Don't trust those sniffers too much. They're cheap and convenient but err fairly often when exposed to random EM fields. Marc Link to comment Share on other sites More sharing options...
Gibsonguy Posted April 28, 2017 Report Share Posted April 28, 2017 Try to get a good one if you can. I have a Klein and I'm not too impressed, but it's MUCH better than my older one (Can't remember the name). My master electrician friend says to go with Fluke. Check the sensitivity so you don't get one that goes off every time you sneeze... Link to comment Share on other sites More sharing options...
adarty Posted May 21, 2017 Report Share Posted May 21, 2017 On 4/27/2017 at 5:23 PM, Denray said: Light in shower of old viki has metal ring around it. My voltage sniffer goes off whether the switch is on or off. How serious is that? The metal shell of lighting fixtures that do not have a ground connected will often cause a voltage sniffer to alert. Link to comment Share on other sites More sharing options...
John Kogel Posted May 22, 2017 Report Share Posted May 22, 2017 (edited) Right, old ungrounded wiring? Call for an upgrade. If an electrician says the wiring is OK, you've done your job anyway, by initiating a closer look. It is pretty common to see the original K&T wiring going to light fixtures, even when the wall outlets have newer wiring installed. A light fixture box could be always energized with one side of the light circuit going down to the switch and back. It is a good idea to carry a second sniffer of a different make to compare results. A really sensitive one might be useful for finding stray voltages on plumbing pipes. I had a garage door track that set off my more sensitive sniffer when the light was switched on. Even tho there was no real shock hazard, it convinced my clients they needed to replace the old wiring. Might have prevented a fire or shock down the road. Edited May 22, 2017 by John Kogel Link to comment Share on other sites More sharing options...
