Annieokie Posted January 20, 2017 Report Posted January 20, 2017 My Townhouse was built in 2006. There are a total of 12. Out of the twelve at least 3 of them have had their firewalls collapse in the attic, including mine. One person had his replaced for $1500. Can the builder be held responsible for this?
Jerry Simon Posted January 20, 2017 Report Posted January 20, 2017 Annieokie said: My Townhouse was built in 2006. There are a total of 12. Out of the twelve at least 3 of them have had their firewalls collapse in the attic, including mine. One person had his replaced for $1500. Can the builder be held responsible for this? Eleven years later? Would probably take a lawsuit (assuming builder didn't go belly-up after 2008). Why did "one" person have his replaced? Wouldn't that have affected two units? Sounds more like a Homeowner's Association thingy.
Annieokie Posted January 20, 2017 Author Report Posted January 20, 2017 He had it replaced, I'm sure for protection. He said company who did the work said it wasn't attached properly. Seems strange that three have fallen within months of each other.
Jerry Simon Posted January 20, 2017 Report Posted January 20, 2017 Annieokie said: He had it replaced, I'm sure for protection. He said company who did the work said it wasn't attached properly. Seems strange that three have fallen within months of each other. What I meant, was, I hope he shared the cost with the adjacent unit. . .
Annieokie Posted January 20, 2017 Author Report Posted January 20, 2017 That's what I was thinking, it would affect two units. Thank goodness I'm on the end, only have one adjoining wall to another unit. So you think the HOA should be the one to handle this legally?
kurt Posted January 21, 2017 Report Posted January 21, 2017 That can only be determined by examining the By Laws of your association. Most of the HOA's that I work with, that would be a common element, i.e., an association issue. Your association may have different regulations.
Jim Katen Posted January 21, 2017 Report Posted January 21, 2017 If they've "collapsed," then they certainly were built wrong. In order for these walls to work properly, you have to have proper coverage on both sides. Just fixing the drywall on *your* side won't have much value. I'd get the board to hire a contractor to fix all of them. It should end up being cheaper for everyone and the work will be better if it's uniform.
kurt Posted January 21, 2017 Report Posted January 21, 2017 That's right. Inasmuch as these little walls can prevent catastrophic disaster, you want a good firewall. I've personally seen what happens when firewalls are incomplete or compromised, and it's bad. Really bad.
Annieokie Posted January 21, 2017 Author Report Posted January 21, 2017 Shouldn't the builder be held accountable for this?
Jim Katen Posted January 21, 2017 Report Posted January 21, 2017 Annieokie said: Shouldn't the builder be held accountable for this? After 11 years, that's a philosophical question with no real point. You're not going to get blood from that particular turnip. Focus on fixing the problem, not assigning blame. Otherwise, you're just going to tarnish your chi.
Jerry Simon Posted January 21, 2017 Report Posted January 21, 2017 Collapsing firewalls. Are they drywall or masonry block?
Annieokie Posted January 21, 2017 Author Report Posted January 21, 2017 My neighbor who had his fixed said the contractor said it was installed with regular nails instead of wood screws.
Marc Posted January 21, 2017 Report Posted January 21, 2017 Annieokie said: My neighbor who had his fixed said the contractor said it was installed with regular nails instead of wood screws. There's nails that will work and nails that won't. Same with screws. Just a poorly done job is all. Marc
Leighton Jantz Posted January 21, 2017 Report Posted January 21, 2017 I agree with Jim, get it fixed, just last week I did an inspection where the unheated,detached garage built in '96 had drywall fastened with nails. The drywall was still up. There may not be enough ventilation in the attic space. There may be mechanical ventilation dumping warm moist air into the attic, making the drywall deteriorate. Or the installer hammered the nail heads though the outer layer of paper. There is several things that could cause this situation, to properly fix it you need someone who knows what they are doing to come and have a look. As to who would pay for repairs, maybe check with your board? Might as well get them all done at once.
Jim Katen Posted January 21, 2017 Report Posted January 21, 2017 Annieokie said: My neighbor who had his fixed said the contractor said it was installed with regular nails instead of wood screws. That, in itself, is not a problem. I suspect that there were, in fact, too few nails and that they were poorly placed.
kurt Posted January 21, 2017 Report Posted January 21, 2017 Annieokie said: My neighbor who had his fixed said the contractor said it was installed with regular nails instead of wood screws. This might be another outgrowth (or tumor) from Holme's show. He's always bragging how he only uses screws instead of nails. I've even had customers comment or ask "did they use screws or nails"; when I question them why they asked, it's always "that's what Holmes does".
Jim Baird Posted January 22, 2017 Report Posted January 22, 2017 Rated assemblies can be put together a number of ways. If there is an HOA maybe they are lucky enough to have some original plans with details that show how things are put together.
