Electrical write up on my brothers house
Brandon Whitmore
7 outlets were accessed and out of the 7 outlets only 2 were correctly
grounded. All others had an open ground. Also there were no GFI outlets
installed. However there was 1 GFI breaker in the panel, but with no labeling
it is unknown if this is for the bathrooms, the kitchen or what it is trying to
protect. Also with this being a 2 wire system with 3 prong outlets installed
this would most likely not work properly even if installed. Contact licensed
electrician to evaluate the entire system and repair as needed.
One of many inspection report issues...
Jim-- maybe you can let this guy ride along with you for a while.....
Link to comment
Share on other sites
