kurt Posted November 25, 2016 Report Posted November 25, 2016 Fiddling with a surface pro 4 and want to know if it will run very basic stuff with 4gb of RAM. I haven't used windows in years and remember the old systems ran SLOW on only 4gb RAM. Would be using one program at a time, basic email, Word, etc. looking for minimal requirements for basic functionality.
Robert Jones Posted November 26, 2016 Report Posted November 26, 2016 Kurt, I wouldn't think you'd have a problem. Windows 10 runs cleaner than the old systems that tended to bog down. At least that has been my experience.
kurt Posted November 26, 2016 Author Report Posted November 26, 2016 Thnx. I got the cheapest of the cheap, 4 GB Ram, 128 GBHD, and...from what I can gather...the bottom of the heap in processors, something called a Core M. All I want it to do is run my FM Pro application, check email, that's it.
ghentjr Posted November 26, 2016 Report Posted November 26, 2016 Thnx. I got the cheapest of the cheap, 4 GB Ram, 128 GBHD, and...from what I can gather...the bottom of the heap in processors, something called a Core M. All I want it to do is run my FM Pro application, check email, that's it. I run windows 10 on my mac through Parallels. Smooth as silk.
John Kogel Posted November 26, 2016 Report Posted November 26, 2016 Windows 10 is good, reliable [:-thumbu] so far. Programs are now called Apps. Avoid the quirky add-ons like Cantana or whatever it is called. You want to allow auto upgrades, so be prepared for invasions of your privacy any time they want. But it is either that or be vulnerable to hackers and spybots.
kurt Posted November 26, 2016 Author Report Posted November 26, 2016 This is only about running my application on a touch screen computer. The iPad version of Filemaker won't bulk import pics, otherwise I'd do it all on an iPad. I need a full tilt operating system and a touch screen. So, it sounds like I can take a cheap pad and make it my report tablet and it'll work.
Les Posted November 26, 2016 Report Posted November 26, 2016 Kurt, what did you pay for the basic surface pro 4? apparently battery issue.
Marc Posted November 26, 2016 Report Posted November 26, 2016 Do you mean there's a graphical capability to FM? What version? Marc
kurt Posted November 27, 2016 Author Report Posted November 27, 2016 Kurt, what did you pay for the basic surface pro 4? apparently battery issue. $664...or something close to it. Battery issue.... like they die, or do they melt? The 3 had major problems. Supposedly, the 4 is ok. Mostly.
kurt Posted November 27, 2016 Author Report Posted November 27, 2016 Do you mean there's a graphical capability to FM? What version? Marc 15, but I don't know what you mean by graphical capability. It will store any type of graphic, I can put any type of graphic in a layout or template.....I can't draw in it like Illustrator though. It's a database with a lot of graphic layout capability.
Marc Posted November 27, 2016 Report Posted November 27, 2016 I should have explained better. By graphical capability I mean that you can move blocks of text, photos, headings, etc with your finger by dragging it on the screen such as you might do when re-arranging the order of findings, headings etc in a report or when you're dragging boilerplate and dropping it off into the report. If that's not it, I'd like to know whatever it is you are doing with FM on the touch screen. Marc
kurt Posted November 27, 2016 Author Report Posted November 27, 2016 Oh, yes. It's a wonderland of graphical capability in that regard. All the stuff you noted, buttons to paste specific text or pics, all my SOP data entry is pull down menus editable within the menu...everything. IT folks get a big grin on their face when they see it.
Steven Hockstein Posted November 28, 2016 Report Posted November 28, 2016 Windows and Mac IOS like to run stuff in the background to keep tabs on us. I shut-off everything I don't need and both operating systems run faster.
Erby Posted November 28, 2016 Report Posted November 28, 2016 I've been using a Surface Pro 3 with HomeGauge for the last couple of years. Very little issues. Never had any problems with the battery. That touch screen finger stuff was initially a pain in the ass, but once I got used to it, I write most of my reports with the finger.
Charlie R Posted December 6, 2016 Report Posted December 6, 2016 I have had the Surface 4 w/4 for about a year, no issues at all, runs everything fine, no battery issues, lasts about 5 hours off the charger.
