jseddy Posted January 5, 2006 Report Share Posted January 5, 2006 I have only seen a couple of forms specific to a draw inspection. I'm creating my own and have used a bank's in the past, but it only had about 10 checks they were looking for throughout the construction. Just don't want to miss anything especially if my logo and name are on the top. Thanks. Jeff Link to comment Share on other sites More sharing options...
Erby Posted January 6, 2006 Report Share Posted January 6, 2006 Most of the construction draw reports I've done, the company and/or bank supplied the form they wanted used. Here's a sample in PDF Format. http://b4uclose.tripod.com/Reports/consdraw.pdf It's actually an Excel worksheet. Each of the percentage cells has a drop down menu to select percentages. If you want the actual Excel worksheet that you can play with (adapt) send me an e-mail at erby@b4uclose.com Link to comment Share on other sites More sharing options...
nspctrdan Posted February 11, 2006 Report Share Posted February 11, 2006 I use HomeGauge report writing system and they include a draw inspection template that has worked well for me. You should be able to view a sample at their site. I started doing draw inspections for a local bank recently and it seems like I've become their 'go to' guy in large part because of the HomeGauge draw template. A bank is looking to CYA on a draw inspection so the addition of pictures to the draw report is invaluable to them. Keep the report short, add photos, don't be shy in estimating degrees of completion and be prepared to tell the bank when a draw is not warranted. Good Luck! I'm not exactly highly seasoned in this field but I'd be happy to talk if you have any questions. Link to comment Share on other sites More sharing options...
DonTx Posted February 12, 2006 Report Share Posted February 12, 2006 I do draw inspections for several national companies and they provide the forms. Pretty simple stuff. For example, they'll want to know when the foudation is done and the wall framing is up. Sometimes they want a %, other times they just want to know when it's complete. Erby's example is the most thorough draw inspection report I've seen, that would be a good starting point if the lender does not have their own form. Link to comment Share on other sites More sharing options...
Scottpat Posted February 12, 2006 Report Share Posted February 12, 2006 This is what my form looks like. I have it setup in Excel. Download Attachment: Percent Complete Bank Form SAMPLE.pdf 51.55 KB Link to comment Share on other sites More sharing options...
randynavarro Posted February 12, 2006 Report Share Posted February 12, 2006 The draw sheet is available at HUD's website. The site is so huge and convoluted but if you work hard enough you'll find it. My experience has been that most all banks will accept the HUD version. You can certainly make your own as it appears others have done. You just have to 'sell' it to each lender to make sure it covers what they need. I have the HUD version in Excel format. I'd send it to you just like Scott P. did but I don't have a PDF converter. Link to comment Share on other sites More sharing options...
DonTx Posted February 13, 2006 Report Share Posted February 13, 2006 Randy, You can go to http://www.gohtm.com and use their free online PDF converter. You just upload your document to their website and it emails you the PDF. After a recent meltdown of my Adobe PDF program, I found this site. Their program is only 15 bucks and much faster/easier to use than Adobe's. Link to comment Share on other sites More sharing options...
