Chad Fabry Posted August 18, 2016 Report Share Posted August 18, 2016 I Inspected a house yesterday that used 8x24 block for the foundation, some of which were cast to look like limestone. The literature stated that it was built in 1895. I realize that CMU's change by locale, but I've never seen this size before. Anyone have any info? I'm reporting that I feel the house was built in the late 1920's for a host of reasons including the block. Click to Enlarge 46.53 KB Link to comment Share on other sites More sharing options...
Bill Kibbel Posted August 18, 2016 Report Share Posted August 18, 2016 Concrete blocks were being formed on-site with a hand powered press by the mid 1880s. No concrete blocks from the 19th century look anything like those in the picture. They're likely from the teens through 20s. Link to comment Share on other sites More sharing options...
Bill Kibbel Posted August 18, 2016 Report Share Posted August 18, 2016 http://www.oldhouseweb.com/how-to-advic ... ocks.shtml Link to comment Share on other sites More sharing options...
Chad Fabry Posted August 18, 2016 Author Report Share Posted August 18, 2016 They look heavy. Link to comment Share on other sites More sharing options...
Marc Posted August 18, 2016 Report Share Posted August 18, 2016 I always wondered about the term 'split' face. The name makes no sense. 'Rock' face, 'Broken Ashler' are more sensible. Marc Link to comment Share on other sites More sharing options...
Bill Kibbel Posted August 18, 2016 Report Share Posted August 18, 2016 Split-face block aren't patterned with a form. It's manufactured by "splitting" a large block into 2 blocks leaving 2 rough faces. Link to comment Share on other sites More sharing options...
mjr6550 Posted August 19, 2016 Report Share Posted August 19, 2016 By the late 1920's block was pretty much standardized as 8x16. As Bill said, there were forms to produce block in the late 1800's. Sizes varied quite a bit, and odd stuff was not uncommon. In 1895 it is still common to see some cut nails used for framing. I look for construction features (gas piping, nails, etc.) to try and get an idea of age. Link to comment Share on other sites More sharing options...
Chad Fabry Posted August 19, 2016 Author Report Share Posted August 19, 2016 The ashlar face block was 8x16. Wire nails. Stamped, not cast butt hinges No gas piping holes Nicely milled and planed joists and sub floor The rest of the place was covered in drywall and vinyl. It always reminds me of a corpse in a coffin. The person looks something like they used to, but they're not the same and there's no going back. Link to comment Share on other sites More sharing options...
BADAIR Posted August 19, 2016 Report Share Posted August 19, 2016 anchor still makes larger & speciality www.anchorblock.com Link to comment Share on other sites More sharing options...
Jim Baird Posted August 19, 2016 Report Share Posted August 19, 2016 ...a neighbor of mine (civil engineer married to another one) built part of a house and garage with site-made CMU's they made by hand with wood slipforms and field stone, which were exposed on a face, 8x8x16. Heavy as could be and masons who laid them cursed the heavens, but they look ok after all. Link to comment Share on other sites More sharing options...
mjr6550 Posted August 25, 2016 Report Share Posted August 25, 2016 Chad, I was reading some old publications about block the other day. From what I read, some blocks were being produced on a very limited basis as far back as about the 1850's, but not much as all until at least 1900. Seems like about 1906 was the real beginning of the industry. I save a few references to blocks about 8 to 10 inches by 24 to 32 inches long. The standardization came about in the 1920's. Click to Enlarge 49.85 KB Here are a couple of good references: Concrete-Block Manufacture-Processes and Machines the manufacture of Concrete Blocks and their use in Building Construction both published in 1906, written by H.H. Rice. Copies are on the web. Link to comment Share on other sites More sharing options...
Chad Fabry Posted August 25, 2016 Author Report Share Posted August 25, 2016 Thanks Mark, I'll read it at lunch time today. Link to comment Share on other sites More sharing options...
mjr6550 Posted August 27, 2016 Report Share Posted August 27, 2016 You must get a lot of time for lunch. Link to comment Share on other sites More sharing options...
mjr6550 Posted August 31, 2016 Report Share Posted August 31, 2016 I was recently reading a book on framing (1909 vintage) and came across a reference to block foundations. It mentions using 8x12x24 block. Download Attachment: Concrete Block-from book titled Framing-1909.pdf 363.2 KB 1 Link to comment Share on other sites More sharing options...
mgbinspect Posted December 30, 2021 Report Share Posted December 30, 2021 (edited) On 8/18/2016 at 3:45 PM, Chad Fabry said: They look heavy. They no doubt are heavy, which reminds me of concrete block made by Superior out of Frederick, MD. Their 8 × 12 × 16 concrete blocks were very dense using pretty consistently fine aggregate and more than average cement. The block were so hard that they would actually ring when tapped with a hammer. They tipped the scale at probably close to twice the weight of a Solite concrete block and could therefore not be set in place with one hand. Installing exceptionally heavy concrete block is an isometric exercise because you can't simply place the block on the mortar bed without squirting the mortar out from under the block. The unit needs to be carefully eased down onto the mortar bed with a slight pause as you cut the mortar vrom the faces. This gives the block time to absorb some moisture from the mortar, which stiffens the bed enough to bear the weight. It's a workout! Edited December 30, 2021 by mgbinspect Link to comment Share on other sites More sharing options...
mgbinspect Posted January 2, 2022 Report Share Posted January 2, 2022 On 8/18/2016 at 7:21 PM, Bill Kibbel said: Split-face block aren't patterned with a form. It's manufactured by "splitting" a large block into 2 blocks leaving 2 rough faces. And, they were awfull to install because they rarely split squarely. (The split faces often would not generally align with the plane of the masonry wall surface. They really needed to be dressed much like stone often is before being installed, but no one ever permitted the extra time needed to do so.) For this reason, I hated working with split-faced block. To me it looked unfinished. Link to comment Share on other sites More sharing options...
Jim Baird Posted January 3, 2022 Report Share Posted January 3, 2022 On 12/30/2021 at 8:14 AM, mgbinspect said: They no doubt are heavy, which reminds me of concrete block made by Superior out of Frederick, MD. Their 8 × 12 × 16 concrete blocks were very dense using pretty consistently fine aggregate and more than average cement. The block were so hard that they would actually ring when tapped with a hammer. They tipped the scale at probably close to twice the weight of a Solite concrete block and could therefore not be set in place with one hand. Installing exceptionally heavy concrete block is an isometric exercise because you can't simply place the block on the mortar bed without squirting the mortar out from under the block. The unit needs to be carefully eased down onto the mortar bed with a slight pause as you cut the mortar vrom the faces. This gives the block time to absorb some moisture from the mortar, which stiffens the bed enough to bear the weight. It's a workout! A mason told me long ago that 12" block were called "birth control" block because no mason could summon the energy for conjugal activity after a day laying them. 1 Link to comment Share on other sites More sharing options...
