Darren Posted August 6, 2016 Report Share Posted August 6, 2016 First time seeing this. This was after my client asked if the tiles had asbestos and I said no, they are not 9x9. Click to Enlarge 46.56 KB Link to comment Share on other sites More sharing options...
kurt Posted August 6, 2016 Report Share Posted August 6, 2016 Just about all the old stuff is ACM. The thing with 9x9 is the EPA said its "guaranteed" ACM. Link to comment Share on other sites More sharing options...
Les Posted August 6, 2016 Report Share Posted August 6, 2016 mega tons of that stuff in commercial bldgs. 9x9" is the most common residential. Kurt is right. Link to comment Share on other sites More sharing options...
Jim Katen Posted August 7, 2016 Report Share Posted August 7, 2016 I remember installing those things. Very difficult to cut. As I recall, we'd mark them and heat the cut line with a torch before scoring them. I can still smell them. Link to comment Share on other sites More sharing options...
Mike Lamb Posted August 8, 2016 Report Share Posted August 8, 2016 Kentile. I thought that was an old pic of mine. Click to Enlarge 65.48 KB Link to comment Share on other sites More sharing options...
Rob Amaral Posted August 10, 2016 Report Share Posted August 10, 2016 Yup.. I've seen the packages with the 12x12 also... I've only seen 9x9 and 12x12 so far.. but... I've only been doing this for a few years.. (21!) Link to comment Share on other sites More sharing options...
John Kogel Posted August 11, 2016 Report Share Posted August 11, 2016 The sheet vinyl flooring also is suspect. The black glue probably always contains asbestos and it was still in use in the late 80's. Link to comment Share on other sites More sharing options...
Charlie R Posted August 13, 2016 Report Share Posted August 13, 2016 All correct, almost any vinyl flooring made up into the 80s could contain asbestos, the black mastic almost always contains a higher percentage than the tiles. Remember, a lot of vinyl baseboard was stuck on the walls with that black mastic also. Link to comment Share on other sites More sharing options...
