Rob Amaral Posted June 22, 2016 Report Posted June 22, 2016 1880 wood frame house, wood siding that had asphalt siding over it.. asphalt deteriorated.. so solution is: (Drum Roll) Click to Enlarge 58.47 KB
Jim Baird Posted June 22, 2016 Report Posted June 22, 2016 ...how better to stand the huff and puff of the big bad wolf?
kurt Posted June 22, 2016 Report Posted June 22, 2016 Did they place a whole 'nuther foundation outside the original?
mjr6550 Posted June 23, 2016 Report Posted June 23, 2016 I would be very concerned with that. From the mortar patching at the side of the window you can see that the wall is significantly out of plumb near the bottom, and it appears that a gap has developed.
mlparham Posted June 23, 2016 Report Posted June 23, 2016 Rob Amaral said: 1880 wood frame house, wood siding that had asphalt siding over it.. asphalt deteriorated.. so solution is: (Drum Roll) Click to Enlarge 58.47 KB Run!!
