Chad Fabry Posted May 28, 2016 Report Posted May 28, 2016 This is not a pre-cast concrete chimney. It is comprised of concrete looking bricks and portland base mortar. Each face of the stack has a visible vertical crack. I couldn't budge the stainless cover to get a look down the chase. I'm leaning toward a mason who filled the cavity between the flue and the chase with concrete. Then the thermal cycles broke the brick. Anybody have any ideas? Click to Enlarge 80.93 KB Click to Enlarge 60.65 KB
mjr6550 Posted May 30, 2016 Report Posted May 30, 2016 My guess is shrinkage cracking. As a full brick shrinks if it is bonded well enough to another brick it causes that brick to fail in tension.
John Kogel Posted June 2, 2016 Report Posted June 2, 2016 It is odd that the chimney split on all sides. If it is shrinkage, fresh concrete bricks maybe, then I think you are correct, something prevented the chimney from downsizing itself.
Chad Fabry Posted June 2, 2016 Author Report Posted June 2, 2016 I'm not really on board with the shrinkage theory. If it was a long wall, I'd get it, but this is a (supposedly) hollow assembly that's free to move. I'd believe shrinkage if the interior of the chimney is packed too tightly, but not if the assembly has the proper clearances.
Les Posted June 2, 2016 Report Posted June 2, 2016 I think it will be the filled cavity. can't think of anything else. shrinkage wouldn't be logical.
Tom Raymond Posted June 2, 2016 Report Posted June 2, 2016 They will find out when they tear it down. If they are inclined to fix it, that is.
Hearthman Posted June 2, 2016 Report Posted June 2, 2016 If they rain rebar down the inside corners, rust jacking can cause this. With a listed metallic vent or chimney you won't see temperatures significant to cause thermal expansion or thermal shock. The listing allows for a maximum interior surface rise of 90?F from ambient.
Chad Fabry Posted June 2, 2016 Author Report Posted June 2, 2016 If they rain rebar down the inside corners, rust jacking can cause this. With a listed metallic vent or chimney you won't see temperatures significant to cause thermal expansion or thermal shock. The listing allows for a maximum interior surface rise of 90?F from ambient. The chimney pre-dates the current gas appliances- it has a ten inch round terra cotta inlet at the base. The basement still smells like fuel oil.
Rob Amaral Posted June 3, 2016 Report Posted June 3, 2016 Liner too tight? Expansion??? Excessive heat at one point (or chronic) from some appliance???
