Steven Hockstein Posted March 25, 2016 Report Posted March 25, 2016 I found this in the floor of an attic. The house is a little over 100 years old. I first thought it was for an old toilet but there is no plumbing on this side of the house. There is no existing mechanical equipment anywhere near this. There is a bedroom directly below. The house has steam heat. Click to Enlarge 36.36 KB
Tom Raymond Posted March 25, 2016 Report Posted March 25, 2016 That's an old thimble. Gas space heater in the bedroom?
John Kogel Posted March 25, 2016 Report Posted March 25, 2016 Tom is probably correct, a stove pipe flange or thimble. See, all that CE makes your mind sharper. [:-graduat
Bill Kibbel Posted March 25, 2016 Report Posted March 25, 2016 Typical old style collar for a coal stove pipe passing through a floor.
mjr6550 Posted March 26, 2016 Report Posted March 26, 2016 I have seen a few of them and recall seeing one with a stove still in place. I suppose if the chimney did not pass through that room they ran the stove pipe through the ceiling and connected to the chimney in the attic.
Bill Kibbel Posted March 26, 2016 Report Posted March 26, 2016 I have seen a few of them and recall seeing one with a stove still in place. I suppose if the chimney did not pass through that room they ran the stove pipe through the ceiling and connected to the chimney in the attic. It was also common practice to pass the coal stove pipe through a ceiling to provide a little heat to the space above.
Steven Hockstein Posted March 28, 2016 Author Report Posted March 28, 2016 Thanks for the responses. This site is a great resource for when I see something new to me. Assuming that it was for a stove pipe and the fact that the house was built with a steam heating system, I have to assume that the original builder installed it, but it was never used.
mjr6550 Posted March 29, 2016 Report Posted March 29, 2016 Where I see things like that the steam heat or whatever they have for heat typically came later.
Tom Raymond Posted March 29, 2016 Report Posted March 29, 2016 Where I see things like that the steam heat or whatever they have for heat typically came later. Yes. There were thimble like this all over my 1870 house. Most likely coal first. Gas lines were installed long after the house was finished. Boiler and baseboard heat in the 1980s.
