Douglas Hansen Posted March 19, 2016 Report Share Posted March 19, 2016 A friend is remodeling his pool house to turn it into an art studio for his wife. It is in the smoky mountains, near the North Carolina / South Carolina border. It's a simple gable roof structure with no attic space. The rafters are 2X10s and there will be 6 inches of insulation in the rafter bays. The climate includes some freezing and snowfall, and in the summer months is hot and humid. Heating and cooling of the space will be from a ductless mini-split, and realistically there will be long periods of time in both winter and summer when it won't be turned on at all. Should he install a ridge vent? Should he supplement that with vent strips near the eave to provide cross-circulation through each rafter bay? Or should he skip the idea of ventilation altogether? Thanks Link to comment Share on other sites More sharing options...
kurt Posted March 19, 2016 Report Share Posted March 19, 2016 Ventilate. Ridge vent and continuous strip soffit inlets. Link to comment Share on other sites More sharing options...
ghentjr Posted March 19, 2016 Report Share Posted March 19, 2016 Ventilate. Ridge vent and continuous strip soffit inlets. Yes. Link to comment Share on other sites More sharing options...
kurt Posted March 19, 2016 Report Share Posted March 19, 2016 Joe talked about this at the PA seminar.....fundamentally, insulation with ventilation works in this sort of elementary assembly. The NC climate isn't extreme enough to warrant the expense of doing anything else. Link to comment Share on other sites More sharing options...
Jim Baird Posted March 19, 2016 Report Share Posted March 19, 2016 ...don't know the local codes there, but accessory to residential is usually supposed to be to residential standard, where R-30 is required for ceilings. 6 inches is R-19. Link to comment Share on other sites More sharing options...
Tom Raymond Posted March 19, 2016 Report Share Posted March 19, 2016 Skip the proper vents and make your own out of foil faced foam. Tuff R is R10. 3 times the vent space, 30% more R value, a radiant barrier that will be much appreciated when the AC is off for extended periods, and far less wash in the glass. Link to comment Share on other sites More sharing options...
kurt Posted March 19, 2016 Report Share Posted March 19, 2016 I agree. There's lots better ways to do this stuff than conventional approaches. As far as hitting R values, I've done stuff like put foam board on the interior under the drywall and 6 inches in the rafters. I like foam board. I don't like fiberglass particularly. And, R values are just one thing. How tight is the building? Tightness rules, AFAIC. Link to comment Share on other sites More sharing options...
David Meiland Posted March 19, 2016 Report Share Posted March 19, 2016 The rafters are 2X10s and there will be 6 inches of insulation in the rafter bays. If he's going to the trouble of insulating, he should use R30 instead of R21. Link to comment Share on other sites More sharing options...
mlparham Posted March 20, 2016 Report Share Posted March 20, 2016 A friend is remodeling his pool house to turn it into an art studio for his wife. It is in the smoky mountains, near the North Carolina / South Carolina border. It's a simple gable roof structure with no attic space. The rafters are 2X10s and there will be 6 inches of insulation in the rafter bays. The climate includes some freezing and snowfall, and in the summer months is hot and humid. Heating and cooling of the space will be from a ductless mini-split, and realistically there will be long periods of time in both winter and summer when it won't be turned on at all. Should he install a ridge vent? Should he supplement that with vent strips near the eave to provide cross-circulation through each rafter bay? Or should he skip the idea of ventilation altogether? Thanks An art studio. Very interesting. I suspect that the local code will not allow a detached room that one might rent. However, if you were to build an "artist studio" of course you will need a bathroom, a kitchenette so that the artist can fix a snack and maybe a place to nap. Next thing you know you have a "studio" to rent. Link to comment Share on other sites More sharing options...
