Mike Lamb Posted September 4, 2015 Report Share Posted September 4, 2015 I have a house that has gable end louvers and ridge vents but no soffits. The ridge venting is new with the roof. Is it even worth mentioning that the two should not be mixed? Would you mention that the attic may be over-vented? I want to recommend the ridge vent be removed. Link to comment Share on other sites More sharing options...
kurt Posted September 4, 2015 Report Share Posted September 4, 2015 How old is the house? What's the sheathing? Reason I ask.... I've never found this to a problem in any way whatsoever on older houses. Yeah, it's wrong, and so what? On new places made with plastic and sawdust, it matters a lot. Link to comment Share on other sites More sharing options...
Mike Lamb Posted September 4, 2015 Author Report Share Posted September 4, 2015 1970's. I saw some minor mold at the north side of the roof sheathing and was thinking about too much upper venting w/o any lower venting sucking the heck out of the house interior. I am thinking the mold might be fairly recent because of the ridge vent being a few yrs old. Link to comment Share on other sites More sharing options...
kurt Posted September 4, 2015 Report Share Posted September 4, 2015 Could be. Kinda hard to tell. All the studies say it's bad, so it's a safe bet it isn't helping. Link to comment Share on other sites More sharing options...
mlparham Posted September 5, 2015 Report Share Posted September 5, 2015 Did you consider that the stains may be from a roof leak? Link to comment Share on other sites More sharing options...
Jim Katen Posted September 6, 2015 Report Share Posted September 6, 2015 Is it even worth mentioning that the two should not be mixed? . . . I've never seen the slightest evidence that mixing gable and ridge vents is a problem. The air in Oregon attics doesn't seem to have read the textbook that show it how to behave. Vents can be described as holes in the roof at a given height. Traditionally, we put some holes low and some holes high. Air is only going to move through these holes when there's a difference in pressure between one side of the vent and the other. Setting aside mechanical ventilation, that difference can come from the buoyancy of hot air or from wind blowing outside. In terms of buoyancy, hot air in an attic doesn't know the difference between a vent near the ridge and a vent high on a gable wall. The air gets hot, it rises, building up pressure, and the air from the high-pressure zone flows out through whatever openings are there. When this air flow out, the attic develops a low-pressure zone near the bottom of the attic and outdoor air flow in there. The thing that boogers-up this process is wind. When the wind blows - even a very gentle breeze - the pressure it exerts on the vent openings is far greater than the measly pressure developed by buoyant hot air. If the wind blows toward a vent opening, hot air isn't going to go out; it's just going to sit there. In fact, outdoors air is going to blow in. And when that happens, the overall pressure in the attic goes up and air is going to leave the attic through whatever opening has the lowest pressure - that might be vent openings low on the roof on the lee side of the building. Different combinations of attic ventilation and wind direction create very complex scenarios that can be very hard to predict. Even Joe L doesn't go there in most of his stuff. It's chaotic and it's the reason that you will find two houses with exactly the same design and venting systems behaving differently when they're oriented in different directions to the prevailing wind. Link to comment Share on other sites More sharing options...
