tim5055 Posted May 26, 2015 Report Share Posted May 26, 2015 Anything in the plumbing code regarding the required depth of buried pool pipes? Link to comment Share on other sites More sharing options...
mjr6550 Posted May 27, 2015 Report Share Posted May 27, 2015 I don't believe there is anything in plumbing codes regarding pool piping, but I did not look this up. There may be some standards out there regarding pool construction, but I am not familiar with them. I am a bit familiar with pool piping, having just fixed mine last week (after spending a month last fall finding where it was leaking). Why do you ask? Link to comment Share on other sites More sharing options...
tim5055 Posted May 27, 2015 Author Report Share Posted May 27, 2015 A question was raised on a pool forum and I didn't know if the plumbing codes had anything. My thought was that they should be at least below the frost line in cases of frost heaving, even if you winterized an drained. Link to comment Share on other sites More sharing options...
kurt Posted May 27, 2015 Report Share Posted May 27, 2015 I've never seen any below frost grade. They're all in the freeze zone around here. Link to comment Share on other sites More sharing options...
ghentjr Posted May 27, 2015 Report Share Posted May 27, 2015 The only reg I am aware of is the propane line to the heater, which has to be 18" around here an the electrical lines. I simply blow out my lines and plug them. No problem with freeze damage in 30 years with the pool. I did have a problem with insects eating through the flexible pvc lines for a period of time. Link to comment Share on other sites More sharing options...
mjr6550 Posted May 29, 2015 Report Share Posted May 29, 2015 A question was raised on a pool forum and I didn't know if the plumbing codes had anything. My thought was that they should be at least below the frost line in cases of frost heaving, even if you winterized an drained. Generally actual frost depth is far less than requirements for foundations. Link to comment Share on other sites More sharing options...
kurt Posted May 29, 2015 Report Share Posted May 29, 2015 We dug a few foundations last winter and the ground was frozen like a rock down about 6'. Code cited frost grade is just an idea. Link to comment Share on other sites More sharing options...
