If an AFCI fails to trip off when the test button is pressed, will it fail in an overload situation?
The breaker could be defective or it may not be properly wired. I once found several AFCI breakers in a condo panel that had the the extra white wire clipped.
No one knows. But it doesn't inspire confidence.
Thanks, Jim, that was eloquent.
I would not write this in any report but can say it here. "when tested, the AFCI breaker failed to inspire confidence in the inspector ." [:)]
Personally I do not care if the AFCI has any confidence in me. I certainly have no confidence in the AFCI.[:-paperba
Thanks Nolan. It was a Square D panel in a 2006 condo rehab. There were other AFCI's in the panel that tripped when I tested them. I will alert my clients about the recall. They might be from that bad batch.
