Aluminum rusts?
Triplex cable has a strand of high strength steel inside the bare grounded conductor. This what is used to attach it to poles and structures. That is what you are seeing in the picture.
That is why you NEVER use cable cutters to just cut through the bare conductor on that cable - it will ruin the cutters
The brown stain is on the "dead end" wrap on, not on the grounded conductor.
http://www.preformed.com/index.php?opti ... &start=100
Tom Corrigan
I'm not sure the neutral conductor of service drops is described within that link.
I had thought that the center strand of that bare stranded cable was steel. The rest were aluminum. The steel strand bears the tension forces. The aluminum provides most of the conductivity.
Aluminum rusts?
No. The word rust, when used in a discussion about corrosion, is reserved to describe the formation of iron oxide.
exactly...it "oxidizes", just like iron, just like us. Burn, baby...
