Lindon Posted April 21, 2015 Report Posted April 21, 2015 A contractor wants to use EZflow for some drainage problems we're experiencing on our property, but I've been reading mixed reviews about EZflow. Some say it stopped working others say it never worked at all. Maybe this is due to bad installations or untrue testimonials. What has been the experience with those of you that are using EZflow for drainage issues?
kurt Posted April 21, 2015 Report Posted April 21, 2015 I used one of their systems for a septic retrofit years ago; worked great. Fantastic, in fact. In theory, they should all work fine; the principles and materials are correct. Methods may be where it fails. Someone messes up the install, it can't work right.
Chad Fabry Posted April 21, 2015 Report Posted April 21, 2015 I've never used the Ezflow but I have used the company's Infiltrator systems and they work awesome.
Les Posted April 21, 2015 Report Posted April 21, 2015 I stayed at a Holiday Inn Express last night and play a Doctor on a soap opera.
Chad Fabry Posted April 21, 2015 Report Posted April 21, 2015 I stayed at a Holiday Inn Express last night and play a Doctor on a soap opera. I realize that my post may have seemed obtuse but, I thought that an endorsement of the manufacturer's other product lines may shed light on the expectation of quality. Aren't you supposed be to tending to your tulips?
Jim Katen Posted April 22, 2015 Report Posted April 22, 2015 A contractor wants to use EZflow for some drainage problems we're experiencing on our property, but I've been reading mixed reviews about EZflow. Some say it stopped working others say it never worked at all. Maybe this is due to bad installations or untrue testimonials. What has been the experience with those of you that are using EZflow for drainage issues? I've seen it used on two projects that I was involved with and it worked well in both. A nearby landowner used it to address drainage problems on his property about 10 years ago and it still seems to be working fine.
