So I arrive to do a footing inspection and the dialog occurred as follows:
Me: that looks like a footing, so you've decided on a trapezoid shaped addition?
Contractor: blank stare
Me: seriously- can't you see that the footing isn't square?
Contractor: Blood leaves his face
Me: I'm pretty sure this is embarrassing, right?
Contractor yells to crew: Measure the diagonals
Crew: within an 1/8 inch
Contractor smugly: That's perfect in my book
Me: your guy held the tape to the inside corner on one side and the outside corner on the other side.
Contractor: lack of blood leaves face stark white
The photo is the next day for the second footing inspection.
29.17 KB
81.94 KB
I made them install foot long pieces of #5 rebar into 6 inch bored holes in the messed up footing on two foot centers. In the first photo you can see Vern and Cletus drilling the holes.
There is #5 bar on 4 foot centers to tie the poured in place wall to the footer. I stuck around for the pour and watched them place the vertical bar.
I followed up with the architect and advised him of the situation and he was OK with the fix.
