tim5055 Posted February 22, 2015 Author Report Share Posted February 22, 2015 Down here radiant heat means wood stove or fireplace insert...we live in an oak/hickory forest full of solid fuel...as for the inner fuel the spirits spectrum is pretty wide and mostly good... Jim GA is a great place. We were in Kenesaw for five years. Lots of nice spirits........ Link to comment Share on other sites More sharing options...
tim5055 Posted March 4, 2015 Author Report Share Posted March 4, 2015 Well, if there was an "all of the above" check box, I would check it because almost all of you had part of the answer. I had a second guy come out today to look things over and give me his ideas and price. He looked it over and said he could suggest several things: 1. New furnace/coil hooked to the existing compressor for a dual fuel set up. 2. New furnace/coil and new compressor ending up with 95% effeciency on the furnace and a 16 SEER 3. Fix what I have and wait for everything to die - then replace it. After running it for a while he said "I don't think any of your heat strips are working. He grabbed his meter and under the house he went. Marc, you were about spot on - 15 minutes later he said they were all dead. 10 minutes after that he had them working again. He explained that these style heat strips are prone to corrosion where they attach. He unplugged and plugged them in a few times and got them going. He said if I plan to keep what I have, that he should,really come back and pull the heat coil assembly out and clean up all the connections as it is only a matter of time before they stop working again. So, he is going to put together some prices and get back to me. When he left hot air was pouring out of the vents....... Link to comment Share on other sites More sharing options...
Awenthomas Posted April 16, 2015 Report Share Posted April 16, 2015 From my opinion, If a heating system is too weak or too powerful for the size of the house won't run properly and make the home uncomfortable. So I will suggest you to concerned with a contractor, he can calculate the actual capacity needed based on industry standards. Link to comment Share on other sites More sharing options...
