Hi guys, its the rookie, I've been following this site as I've been taking the HI course and wouldn't you know on my second practice inspection for CAHPI, I believe I've come across UFFI, I found an old thread from '10 where there was a picture but this looks slightly different. It has the consistency of peanut butter but it's not sticky. Was I correct? I just pushed down on it I didn't try to break it up.
41.19 KB
UFFI is slightly yellowish. When you break some off and rub it between your fingers it goes to super fine powder. Peanut butter doesn't describe it; it's really dry and powdery when you smash it.
Do you have a close-up pic? Preferably some in your hand?
In my area, old UFFI is pure white and it's never perfectly flat like that. It looks like meringue. As Kurt said, it breaks into a very fine powder - almost like flour - when you rub it.
The stuff in your picture looks like blown-in white fiberglass.
I'm having a hard time visualizing an insulation that's anything like peanut butter.
That isn't UFFI. It looks like smashed down Low density fiberglass.
For future reference, UFFI is more white than yellow....it's only very slightly yellowish. Never seen pure white UFFI around here.
I've seen UFFI that is almost orange. I would attribute the color variation to tannin stains.
Did they really flood attics with the stuff? There is far too much water in the modern counterparts for that to be viable.
Not UFFI in photo. Agree with other posters. I have found a relationship between the color and the density/weight. Most pure white is really light, can't feel a baseball size piece in your palm. The yellowish seems to have more weight and a little less likely to powder.
We see lots of it in Mid-Michigan. It has caused us a lot of stress over the years.
I'm pretty sure there is zero intact UFFI left. Everything I've seen is crumbling and the surface of exposed UFFI is 40 years old now and so it always has a substantial layer of dirt and rodent scat.
The photo looks like wet-spayed cellulose.
I don't find it much nowadays, maybe once every several years, but it's intact. When we've opened walls with it, it's intact and functional. Maybe it's different elsewhere. Lots of it got installed badly....that'll make it fail real quick.
We put it in a lot of Kalamazoo houses years ago. It's the only retrofit material that actually worked reasonably well.
There are neighborhoods in our area that are nearly 75% uffi'd. It worked really well if applied correctly.
I think the original post sure looks like wet cellulose.
well I'm glad I went back before handing in report, in my defence, the insulation is VERY light coloured grey and because they sprayed right over soffit vents there is a 1" spongy/ moist layer on top. It's cellulose fiber. Guess I learned my lesson, go ahead and get my fingers dirty. If they clear insulation from soffits, cellulose won't dry out will it?
33.66 KB[:-banghea
Wet cellulose turns to paper mache. If it's not soaked all the way through, it can still provide some insulating capacity. Density is good; it provides some decent level of air sealing.
