Condensate drain line into TPR drain line????
From the IRC
P2803.6.1 Requirements of discharge pipe. The outlet of
a pressure relief valve, temperature relief valve or combina-tion
thereof, shall not be directly connected to the drainage
system. The discharge from the relief valve shall be piped
full size separately to the floor, to the outside of the building
or to an indirect waste receptor located inside the building.
In areas subject to freezing, the relief valve shall discharge
through an air gap into an indirect waste receptor located
within a heated space, or by other approved means. The dis-charge
shall be installed in a manner that does not cause per-sonal
injury or property damage and that is readily
observable by the building occupants. The discharge from a
relief valve shall not be trapped. The diameter of the dis-charge
piping shall not be less than the diameter of the relief
valve outlet. The discharge pipe shall be installed so as to
drain by gravity flow and shall terminate atmospherically
not more than 6 inches (152 mm) above the floor. The outlet
end of the discharge pipe shall not be threaded and such dis-charge
pipe shall not have a valve installed.
Plus with the two of them tied together, then how would you differentiate condensate from TPR discharge (or leakage); the latter indicating you might have a potentially serious problem with the water heater?
Jeff Euriech
Peoria, AZ
