Amycampbell3 Posted December 9, 2014 Report Share Posted December 9, 2014 We went through major mold issues over the last few years. Although it was remediated, we still suffer health side effects. We have been told once it as bad as we had it, you will never be 100% mold free. In the winter when heat is on, we feel much worst. We have had vents cleaned, HVAC checked. We are now looking for a solution to clean air. Has anyone had luck with ERV, air scrubber or anything else?? Thanks in advance for any info! Link to comment Share on other sites More sharing options...
Les Posted December 9, 2014 Report Share Posted December 9, 2014 You will not have a mold free house. I use an ultra-violet light and media filter with good results. If your house is making you sick and you have done typical measures, it may be time to move. Link to comment Share on other sites More sharing options...
Marc Posted December 9, 2014 Report Share Posted December 9, 2014 It may be that the occupant has developed an elevated sensitivity to a particular species of mold or mycotoxin as a result of previous exposure to high concentrations that currently remains in that house in normal concentrations (comparable to outdoor concentrations). What Les said...move. Marc Link to comment Share on other sites More sharing options...
Jim Katen Posted December 9, 2014 Report Share Posted December 9, 2014 Or it might have absolutely nothing to do with mold, and the pre-occupation with mold is blinding you to whatever the real problem is. Link to comment Share on other sites More sharing options...
Marc Posted December 9, 2014 Report Share Posted December 9, 2014 Or it might have absolutely nothing to do with mold, and the pre-occupation with mold is blinding you to whatever the real problem is. Indeed. Marc Link to comment Share on other sites More sharing options...
Jerry Simon Posted December 9, 2014 Report Share Posted December 9, 2014 I'm with Les. Like Sam Kinison once opined about folk living in a desert: If you don't like the heat, and you don't like the fact that there's little water . . . MOVE! Link to comment Share on other sites More sharing options...
kurt Posted December 9, 2014 Report Share Posted December 9, 2014 We had a customer a while back that repeatedly claimed mold was making her sick. She'd had $40,000 (yes, that's 40k) of remedial work done, 3 different well known HVAC contractors checked the systems, and various other trades look into paint toxins, or other possibilities. She was still sick with bad respiratory issues. She got our name from someone and wondered if we could figure anything out. We went out and in <5 minutes found an air return in the attic that was broken in half and sucking fiberglass insulation and blowing it through the house. Point of story...... Until there is a bullet proof and valid examination of the entire house by someone looking for any and all possibilities, who knows? Are you getting your health advice from mold people and home inspectors, or are you getting your advice from a trained allergist/medical professional that's looked into all the possible issues in your house and/or life? Having been through this general storyline too many times over the last several years, I've become highly cynical and suspicious of all claims relating to mold. Everyone thinks what's bothering them is mold. Maybe. Maybe not. Every house is full of mold. The keyboard you're typing on has a few million spores on it. So does every other surface in your house. Every "mold test" I've reviewed, and I've reviewed a lot of them, shows more mold outside in the ambient air than mold inside the house, yet the reports all point to indoor mold being the problem. The idea that you can get "100% free of mold" is a fallacy. Maybe you do in fact have extreme mold sensitivities. I don't know. But until I had a chance to check the house out myself, or by someone that I know and trust, I'm skeptical that mold in your very clean and remediated house is a problem. Link to comment Share on other sites More sharing options...
Amycampbell3 Posted December 10, 2014 Author Report Share Posted December 10, 2014 Kurt- We had stucco problems, specifically the windows were not flashed. When the walls were taken down, there was black mold everywhere. We replaced three walls that were stucco. When I say replaced, we rebuilt the whole wall including dry wall. We no longer have stucco. Over the last few years we had other leaks that caused mold. I definitely think my husband developed a sensitivity to it. With all the luck we have had with this house ( sarcastic), I wouldn't be surprised if it is a new issue effecting him. He travels for work and is fine then comes home and feels sick again. We have been ripped off many times, given bad advice, etc. we are finding it hard to find anyone to help us figure it out. We are in Chester county, PA. Do you know anyone that is a reliable source that could help us?? Thanks!! Link to comment Share on other sites More sharing options...
kurt Posted December 10, 2014 Report Share Posted December 10, 2014 Badly leaking house repaired, but still some leaks in other locations. Sounds like a mess of lousy construction. Sorry to hear. OK, could be mold after all. I'd ask Bill Kibbel; he works PA and NJ. He's in here and will probably read this. He might be able to help. If not, he probably knows someone who can. Link to comment Share on other sites More sharing options...
Amycampbell3 Posted December 10, 2014 Author Report Share Posted December 10, 2014 Thanks for your help, I will contact him. And yes, all the houses in our neighborhood were made poorly. The builder cut corners everywhere. A lot of out neighbors have mold/ stucco problems too. Link to comment Share on other sites More sharing options...
Les Posted December 10, 2014 Report Share Posted December 10, 2014 Amy, Was it real stucco or an insulated exterior call covering; known as EIFS or Dryvit or etc? There are nationally recognized experts on this forum for either material. The process of helping you is really simple for qualified people. It can not be done on this forum, but we sure can help direct you to qualified people. Your question has been seen by the best in the nation. Geography has a lot to do with finding the best person. Keep us posted. Link to comment Share on other sites More sharing options...
Awenthomas Posted April 10, 2015 Report Share Posted April 10, 2015 Hi Amycampbell3, Run a HEPA air purifier to capture mold spores that have become airborne. HEPA air purifier is an effective solution. Place the air purifier in the room, where you believe the mold is growing. It will capture 99.9% of the entire airborne mold which passes through its filters. Hope this solution will be helpful for you. Thanks!!!! Link to comment Share on other sites More sharing options...
John Dirks Jr Posted April 11, 2015 Report Share Posted April 11, 2015 Sooner or later there's gonna be a link dropped in here. Come on now, where's the magical cure? I'm dying (of mold exposure) to know what it is. Link to comment Share on other sites More sharing options...
mlparham Posted April 11, 2015 Report Share Posted April 11, 2015 Has your home been checked for micro particulates from a gas appliance or even a nearby freeway? Link to comment Share on other sites More sharing options...
lucygrey Posted April 29, 2015 Report Share Posted April 29, 2015 have you establish a gas detector to find harmful gases? Link to comment Share on other sites More sharing options...
Erby Posted April 29, 2015 Report Share Posted April 29, 2015 You can spend a crap load of money trying to isolate the problem. I'd Move On! Link to comment Share on other sites More sharing options...
Garry Sorrells Posted May 4, 2015 Report Share Posted May 4, 2015 .......... Until there is a bullet proof and valid examination of the entire house by someone looking for any and all possibilities, who knows? Are you getting your health advice from mold people and home inspectors, or are you getting your advice from a trained allergist/medical professional that's looked into all the possible issues in your house and/or life?..................... You may be fixated on mold as the cause of your what you think you are experiencing. You may also be attributing the house interior as the source when in fact it may be a delayed reaction to something outside the house that you are in contact with. It is very possible that mice/rat droppings and their urine may be affecting you. Symptoms are very similar to your description. If you go looking for mold you will find mold, because it is everywhere and natural. You need to work from a less predetermined causal position. Most filters and the like only reduce circulation if it is in the duct system. If the system/house is prone to mold generation it will return. If it is something in a gaseous state most filters will not stop transference. The possible solution may be in air scrubbers that work on various levels and is not an off the shelf purchase. BUT, you have to know what you are really going after first. Link to comment Share on other sites More sharing options...
