The Honest Handyman Posted December 9, 2014 Report Posted December 9, 2014 I have a Wesco electric furnace. I have recently inspected it and everything is working correctly. I did notice that one of the heat strips glows brighter than the other strips. I am wondering if replacing all the heat strips would improve the efficiency or performance of the furnace. I tested the resistance of the wires and they all are about the same. Thanks, Jack
Jim Katen Posted December 9, 2014 Report Posted December 9, 2014 The coils are roughly 100% efficient. There would be no benefit to replacing them. The brighter coil is probably wired by itself while the others are a pair or pairs. You might try measuring the amp draw at each coil when they're all on.
