TimWhalen Posted December 3, 2014 Report Share Posted December 3, 2014 I am renovating a room and turning it into a bathroom. I have two marble slabs with cutouts for undermount bowl sinks. They are probably original to this 1889 house whenever plumbing was installed. I am guessing 1920-1930. They are stained and in need of cleaning. Can anyone direct me to the best source of information to clean marble? I am not aiming for perfection here just a renewed/cleaner look. Thanks. Link to comment Share on other sites More sharing options...
Chad Fabry Posted December 3, 2014 Report Share Posted December 3, 2014 I used re-purposed marble from a building exterior in my bathroom, and marble on our kitchen counters is two inches thick and spent the first hundred years of its life as a building component separating the stalls in a men's room in a court house. Given its previous life, cleaning the marble was important, but each of the pieces had pits from acid rains from various sources. We cleaned with bleach a few times and then I bought a wet polishing set-up which is basically a 5 inch angle grinder with a hole through the arbor. One attaches a hose to the tool and using pads ranging from 50 grit to 4,000 grit you polish to the desired luster. Most of the stains were gone after a few minutes and the counters were completely resurfaced in a few hours. I stopped at 800 grit in the bathroom which leaves a satin, honed finish and I went through 3,000 in the kitchen which is almost a full gloss. You can find Chinese kits including the grinders and pads for less than 200 bucks. Rust stains will not come out. Link to comment Share on other sites More sharing options...
