Les Posted November 18, 2014 Report Posted November 18, 2014 I need a code reference for poured concrete wall exterior insulation. Ext foam 2". How do you treat the seams and what is an acceptable method of fastening material to wall? My discussion is regarding physical deterioration and protection, photo chem deterioration and how to seam/join to eifs. anything will help. thanks
kurt Posted November 18, 2014 Report Posted November 18, 2014 Going backwards. Drainage/waterproofing system on the outside, insulation system on the inside. My fallback references Delta Systems or equal as an acceptable waterproof system and a couple of options for interior insulation with a nod to Joe L. Getting strung up on anything else is just trouble.
