normtyler Posted November 9, 2014 Report Posted November 9, 2014 Customer said he thinks his well is a "shared well", and this weird red gizmo is attached from the breakers back to the neutral bus. What the what? Anyone seen one of these before? My guess is that maybe it is used to sense when the neighbor is powering the well and prevents simultaneous voltage supply? I have no other idea unless it's an early version of GFCI protection? It's in a Federal Pacific box as a bonus Click to Enlarge 52.92 KB
Scottpat Posted November 9, 2014 Report Posted November 9, 2014 Surge protector? Love the double taps......
Bill Kibbel Posted November 9, 2014 Report Posted November 9, 2014 Yes, it's a surge protector supplied by the well pump manufacturer. Many of the older ones are tear drop shaped or heart shaped. They're usually hanging out of the pump control box.
John Dirks Jr Posted November 10, 2014 Report Posted November 10, 2014 Surge protector? Love the double taps...... The double taps are actually the surge protector connections. I do see an unmarked white being uses as hot though.
mjr6550 Posted November 10, 2014 Report Posted November 10, 2014 Surge protector? Love the double taps...... The double taps are actually the surge protector connections. I do see an unmarked white being uses as hot though. Is it required to color code the wire on a 240-volt circuit? I thought that only applied to relatively large gauge wires, but I'm not sure. The top 20 amp breaker is interesting.
John Dirks Jr Posted November 10, 2014 Report Posted November 10, 2014 Yes, The white insulated conductor (normally used as neutral) should be marked when used as a hot. Not only in the main and sub panels but also in appliance disconnects such as at the AC unit. I've seen them taped with black tape or red tape. I also see them colored with either black or red marker magic marker pen.
John Kogel Posted November 10, 2014 Report Posted November 10, 2014 Surge protector? Love the double taps...... The double taps are actually the surge protector connections. I do see an unmarked white being uses as hot though. Is it required to color code the wire on a 240-volt circuit? I thought that only applied to relatively large gauge wires, but I'm not sure. The top 20 amp breaker is interesting. I see 30 amp with a too small gauge wire on it. [:-thumbd] Old installations, the color coding is irrelavent, not required back in the day. JMO, I am no authority on the NEC.
normtyler Posted November 10, 2014 Author Report Posted November 10, 2014 Thanks guys. Every day I see something new. If not, I'm not looking hard enough.
