I have never observed a roof framed with other than rafters or engineered roof trusses - that is until yesterday.
Yesterday I inspected a 1986 rural built home with roof framing that ran parallel to the home's load-bearing walls.
Has anyone every observed a roof framed in this manner?
46.38 KB
Yes, as long as the rafter ties are there, it's not a problem.
In this case they wouldn't be rafter ties, they'd be ceiling joists. There is no outward thrust- each framing member is a beam and all the load is vertical.
If the walls are not load bearing then beams are needed to transfer the weight of the roof/ceiling assembly to load bearing columns.
It's akin to an ordinary house with a garage; a beam across the front of the garage opening transfers the weight of the ceiling and roof to the sides.
I see this done in some old row houses with low-sloped gabled roofs. Just think of it like a flat roof-ceiling joists spanning from bearing wall to bearing wall. There is an issue with this type of framing when used on a roof that does not have a relatively low slope. The roof load is partially transferred to the narrow dimension of the joist and therefore the joists cannot span as long as if they were oriented vertically.
  • 5 months later...
