Jerry Lozier Posted July 23, 2014 Report Posted July 23, 2014 2001 (vacant for a couple months) home. Trying to figure out what this 2" ABS pipe is for. Old stains, standing water and dripping water from pipe after I ran a bunch of faucets in the home. It was near a bathroom, which was behind bearing wall... any ideas?? Click to Enlarge 52 KB Click to Enlarge 55.5 KB Click to Enlarge 39.5 KB Click to Enlarge 43.81 KB
fyrmnk Posted July 23, 2014 Report Posted July 23, 2014 Laundry room floor overflow drain by chance? Doesn't explain water dripping out from faucets running though.
John Dirks Jr Posted July 23, 2014 Report Posted July 23, 2014 Perhaps a mistake in the system design that was overlooked and never corrected?
John Kogel Posted July 23, 2014 Report Posted July 23, 2014 Could it be coming from the water heater drain pan? That is my first guess. I see them like that fairly often with 1 1/2 pipe. Maybe it's an extension. The tank may be leaking, regardless of the faucets.
Jerry Lozier Posted July 23, 2014 Author Report Posted July 23, 2014 Could it be coming from the water heater drain pan? That is my first guess. I see them like that fairly often with 1 1/2 pipe. Maybe it's an extension. The tank may be leaking, regardless of the faucets. At least 30' from water heater, and laundry areas... bizarre.
David Meiland Posted July 23, 2014 Report Posted July 23, 2014 Floor drain with a trap primer? I would only expect 3/4" PVC from a water heater pan.
Jim Katen Posted July 23, 2014 Report Posted July 23, 2014 Looks like a shower drain that never got connected.
