Sure. No need for conduit or even bushings if it's passing through wood.
I'm sure you're already aware of the other issues shown in the photo.
Is it okay to run Romex straight through holes bored in the floor? Should there be some kind of raceway or conduit?
40.36 KB
Depends on where it goes. If it's exposed above the point where it passes through the floor, then it should be protected by a section of conduit that extends at least 6" above the floor. If it's not exposed, then it needs nothing. 334.15(B)
  • 4 weeks later...
Depends on where you are located.Some places allow romex to be exposed in an unfinished basement,some places don't.
The romex below the joist is a problem though.
Agreed. But the issue is what is needed above the floor, not below it.
