Ben H Posted June 26, 2014 Report Posted June 26, 2014 In a ten yr old condo today with 4 CSST runs. Other units all around and no easy access to the panel. However the plumbing bond was less that 2 ft away from the gas lines. My question is could you connect the bonding wire of the gas line over to the plumbing bond?
Chad Fabry Posted June 27, 2014 Report Posted June 27, 2014 In a ten yr old condo today with 4 CSST runs. Other units all around and no easy access to the panel. However the plumbing bond was less that 2 ft away from the gas lines. My question is could you connect the bonding wire of the gas line over to the plumbing bond? Sure
