I am extending a half inch gas line for a gas BBQ outside. The run is approximately 40 feet.
How many in line valves do I need? Is there a requirement to insert a valve every several feet?
  • 1 month later...
Are you going to have enough gas to feed it by the time it gets out that far with 1/2" pipe?
It may not be required but it would be nice to have a shut off someplace just out side of house in case something happens,Id also have a shut off inside before tie in point for same reason.
