Ben H Posted June 15, 2014 Report Posted June 15, 2014 http://img.diytrade.com/cdimg/502044/16 ... _board.jpg Found this on the G.
AmeriSpecguy Posted June 15, 2014 Report Posted June 15, 2014 Just put up green board in my bathroom and it's exactly as is pictured above.
Jim Katen Posted June 15, 2014 Report Posted June 15, 2014 I thought that green board had gone the way of the floppy disc. All I see in damp areas is purple board or paperless.
ghentjr Posted June 15, 2014 Report Posted June 15, 2014 No purple here. Still green on one side only.
Ben H Posted June 15, 2014 Report Posted June 15, 2014 I thought that green board had gone the way of the floppy disc. All I see in damp areas is purple board or paperless. Back in early 2000's when I was at Lowe's we non-stocked the green stuff, brought in the new fancy fiberglass faced stuff. Nearly twice the cost. No one bought it because of it. Non-stocked the fiber stuff, and they still have the green today. I've never seen anything that makes me believe the green stuff really does anything special.
Jim Katen Posted June 15, 2014 Report Posted June 15, 2014 I thought that green board had gone the way of the floppy disc. All I see in damp areas is purple board or paperless. Back in early 2000's when I was at Lowe's we non-stocked the green stuff, brought in the new fancy fiberglass faced stuff. Nearly twice the cost. No one bought it because of it. Non-stocked the fiber stuff, and they still have the green today. I've never seen anything that makes me believe the green stuff really does anything special. The green stuff is, and has always been, crap. The thing that bothers me the most about it is that the gypsum core is so soft and mushy/crumbly. The new purple stuff is better. The fiberglass stuff is great, but it has a finish texture to it that limits its utility in a space where you need it to blend in with regular drywall. Personally, I feel that, if have an area that's going to get wet, you need to make that area impervious to water. If you have an area that's going to get damp enough to damage regular drywall, then you have a badly designed area.
Mike Lamb Posted June 16, 2014 Report Posted June 16, 2014 The back side is green for about a 1/8" - 1/4" around the edges.
Tom Raymond Posted June 16, 2014 Report Posted June 16, 2014 And I thought it was green to indicate that each sheet cost more...
brickbybryck Posted August 10, 2014 Report Posted August 10, 2014 Around 2006 or so codes changed not allowing paper covered water resistant drywall to be used as a tile backing product.greenboard bye bye Cement board hardy panels, dura rock ,ect behind tile.
mjr6550 Posted August 11, 2014 Report Posted August 11, 2014 I thought that green board had gone the way of the floppy disc. All I see in damp areas is purple board or paperless. A few years or so ago I thought that the manufacturers made a big deal out of "purple is the new green". I have not looked in stores recently, but when I have seen unfinished drywall in wet areas it has been purple.
