rlskfoster Posted September 28, 2005 Report Posted September 28, 2005 Did a house today that did not have the drip edge flashing. I found in a Burgess where it says that the drip edge flashing is not required on all roofs. I think it should be there but now I've confused myself. Any old roofers out there know for sure. We really don't have a large freeze problem in this area. Shingles had a good 3/4 to 1 inch overhang. In the picture you can see the vinyl siding. I think the siding guys pulled the drip edge off to make their installation easier, smoother, etc. Thought? Buster Download Attachment: Edmunds 028.jpg 87.45 KB
hausdok Posted September 28, 2005 Report Posted September 28, 2005 Hi, The ARMA and NRCA manuals both recommend drip edge flashing and the rakes and the eaves of all asphalt roofs. Some manufacturers require it or the warranty is void, but that knowledge doesn't do you a whole lot of good unless you have the ability to look at an asphalt shingle and know who manufactured it and what each manufacturer's requirements are. That said, it's used about 1/2 of 1% of the time on homes out here on Puget Sound. Roofers out here extend the felt and the edge of the roof about 2 to 2-1/2 inches into the gutter and call it a day. Consequently, I find rot at the edges of the deck on about 5% of the homes I look at where it's been omitted. I write it up every time I find it, but I tell people not to expect anyone to do anything about it, 'cuz that's just the way it is around here. Any customer that has ever asked for it to be repaired has been turned down flat. ONE TEAM - ONE FIGHT!!! Mike
kurt Posted September 28, 2005 Report Posted September 28, 2005 I think it's epidemic. It's eliminated from the equation around here; if you bring it up, no one even know's what it is.
Jim Morrison Posted September 28, 2005 Report Posted September 28, 2005 That's funny. I see drip edge flashing on nearly every roof I inspect. I don't usually mention it's absence, though, unless it's causing a problem like Mike described.
Bill Kibbel Posted September 29, 2005 Report Posted September 29, 2005 25-30% have it around here on single layer roofs. Roof-overs have a much higher percentage of it as it is used to hide the first layer.
rlskfoster Posted September 29, 2005 Author Report Posted September 29, 2005 Virtually every roof I look at down here has it. When I saw it missing today my first thought was I can't believe they left it off. The more i thought about it I thought I remembered reading it was not an absolute. Thanks for the info. Buster
Brian G Posted September 29, 2005 Report Posted September 29, 2005 I still see a lot of the old wood strip drip rails here, mixed with the metal. If I don't see one or the other I note it in the report, but not as a problem unless there is one. Brian G. Wood is Good, But Metal is...Betal? []
Garcha Posted September 29, 2005 Report Posted September 29, 2005 The first time I saw a $300,000 house with no drip and no felt I almost fell off my ladder. Every roofer I talked to said it was "common". I write it up as defect and mention manufacturer blah, blah, blah. Oh yeah i also mention nuisance leaks being possible and more likely with age. Mike Garcia Sometimes I feel all alone.
Bruce Thomas Posted October 3, 2005 Report Posted October 3, 2005 When I was installing roofs ( about 30 years ago, (that's difficult to say)) we always used drip edge. It makes for a cleaner looking job. If you allow the shingles to overhang the gutters too far they tend to droop in and allow water to wick up behind them. In this area almost all roofs have drip edge. I put vented drip edge on my house because I have no soffit. Brian, How can you mix wood and metal, that must make a strange aloy? [:-bigeyes Bruce
Garcha Posted October 4, 2005 Report Posted October 4, 2005 Bruce, The only material suitable for drain pans in certain residential applications is the new Betal alloy. Mike Garcia Digging a very deep ditch.
