Ben H Posted January 5, 2014 Report Posted January 5, 2014 Looking for a dimmer that will go from 100%, to a preset dimmed setting, then to off. All I found at Lowe's was Off-to-Preset On. Do they make one that adds that Full on position. Hell even a 3 button decora with a slider for the dimmer would be fine.
Jim Katen Posted January 5, 2014 Report Posted January 5, 2014 I've never seen one. You could rig something easily enough with a 2-gang switch box, a single-throw, double-pole switch, and a preset dimmer switch. . . When the spdt switch is up, the light is full on, when the spdt switch is down, power is routed through the preset dimmer.
kurt Posted January 6, 2014 Report Posted January 6, 2014 I've seen some Lutron electronic programmable types that will do that, but personally, I find them aggravating. You have to stand there tapping and holding to get it to do the tricks. I like Katen's idea better. Simple.
John Kogel Posted January 6, 2014 Report Posted January 6, 2014 You need a rotary switch that can handle 120 VAC. I suppose you could take one from a lamp. But I would never install a lamp switch in a wall box.
Ben H Posted January 6, 2014 Author Report Posted January 6, 2014 You need a rotary switch that can handle 120 VAC. I suppose you could take one from a lamp. But I would never install a lamp switch in a wall box. Want I really want is to 3 buttons. Top button 100% On, middle button drops to a preset dimmed level, and the bottom is off. I can't be the first person to need such a device.
kurt Posted January 7, 2014 Report Posted January 7, 2014 Look at Lutron. I'm pretty sure they make a Decora type programmable that does what you describe. I've seen and operated similarly operating types in the wonder palaces of the 1%.
