Mike Lamb Posted September 9, 2013 Report Posted September 9, 2013 I inspected a 1 yr old metal deck that has advanced rust IMO. From what I have read, all rust should be removed before re-painting a metal deck/porch. That could be a tough or impossible task. Is there a definitive, or at least a good source on painting rusting steel?
Jim Katen Posted September 10, 2013 Report Posted September 10, 2013 Give it a good once-over with a wire brush and prime it with Mar-Hyde.
rkenney Posted September 10, 2013 Report Posted September 10, 2013 Earl Scheib Earl Scheib is no good, there are no wheels to paint. Seriously, if you can pull it away from the house (just easier), sand blast then prime and paint. If by advanced rust you mean perforations after you remove all the rust then it must be replaced. You can't paint rust!
hausdok Posted September 10, 2013 Report Posted September 10, 2013 It depends on how heavy the metal is and how long it's been left to rust. If the steel is still tenable, it can be sand blasted and then coated with POR15 followed by an epoxy primer and the rust will stop. ONE TEAM - ONE FIGHT!!! Mike
kurt Posted September 10, 2013 Report Posted September 10, 2013 Mike's probably talking about these steel egress stair assemblies that have proliferated in Chicago. None of them were primed correctly in the factory, they slap them up, paint them with a single coat of exterior enamel, then they subject them to foot traffic. Every winter they freeze up and tenants dump mountains of salt on them. The one's I've seen refinished cost about $7,000 for a crappy job that'll get you a couple years, and about $15,000 for something that might last a while if they don't put salt on it.
omagic12 Posted November 14, 2013 Report Posted November 14, 2013 Wire brush and (optionally) use The Works toilet bowl cleaner to help remove rust. Afterwards coat with Ospho https://www.google.com/#q=ospho&tbm=shop turns rust to black. Similar to POR-15, but cheaper. If you paint over it give it a few days to dry out first and do not get it on concrete as it will etch.. I learned the stupid way. However, as others have stated it does depend on the depth of the rust.
