The main disconnect must be upstream, since there is no main breaker and too many disconnects for your 6 breaker rule.
So the solid copper grounding conductor should not be landing on the neutral bus.
The 40 amp stove circuit is an old 3-wire hookup. If the stove is newer, I guess it needs that 3rd wire to act as a neutral for the dashboard instruments and 120 v receptacles to work. I will call for a wiiring upgrade when I see that.
