Large old cast iron steam tube boiler (1960s).
It is not insulated - and there are two of them and they cause A LOT of heat.
Can they be insulated or will it cause issues?
It is quite likely that it has ceramic fiber or rock wool insulation blankets between the boiler shell and the jacket. If the surface temp is < 130F, it's insulated.
The rear of the boiler is radiating a fair amount of heat.
The rear of the boiler is a door to access the tubes. The door is lined with refractory cement that can fail and need replacement.
