Scottpat Posted June 27, 2013 Report Posted June 27, 2013 I found this yesterday while doing a new construction inspection. The "pot" filler handle 6 1/2" above the rear burner and it sticks out over the burner about 2"..... They could have moved it another 10" or so to the middle which would have been over the downdraft vent and not over a burner.. Honestly, do folks who install this stuff ever think about what they are doing? Click to Enlarge 48.72 KB Click to Enlarge 68.71 KB
Tom Raymond Posted June 27, 2013 Report Posted June 27, 2013 Those two components are rarely spec'd at the same time, let alone by the same person. I'd wager that they didn't know what cooktop they were going to get until the granite fabricator asked. By then the plumbing was long since roughed in.
Scottpat Posted June 27, 2013 Author Report Posted June 27, 2013 Those two components are rarely spec'd at the same time, let alone by the same person. I'd wager that they didn't know what cooktop they were going to get until the granite fabricator asked. By then the plumbing was long since roughed in. Makes you wonder what the builder is doing that he did not see this, does'nt it!
gtblum Posted June 27, 2013 Report Posted June 27, 2013 I'd wager that they didn't know what cooktop they were going to get until the granite fabricator asked. By then the plumbing was long since roughed in. They must have had a cartoon of the kitchen layout ahead of time. It could be as simple as someone installing different sized cabinets on the opposite side of where they should have been. That would shift the cook top base with them. Do you have a picture of the layout, Scott?
Scottpat Posted June 28, 2013 Author Report Posted June 28, 2013 A folding ruler? That's cool, Scott. Best investment you could make for our profession. Makes a great pointer and is perfect for pictures. An old departed friend (Norm Sage) got me to using it about 10+ years ago. No plans for me to look at. My guess is that the filler was an afterthought.
gtblum Posted June 28, 2013 Report Posted June 28, 2013 No plans for me to look at. My guess is that the filler was an afterthought. I was actually hoping you had an overall of what's there. Not the print Being a finish carpenter, I'm not real quick to let plumbers slide, but in this case, maybe. If they planned for a 32" base on one side, and a 36" base on the other side of the cook top base, and they got switched by a speed demon trying to get it done, there's a 4" shift in the placement of the cook top base and 0" in the overall run. It's easy to forget how works in the real world. These guys are working on a schedule. They do this every day, unlike Joe homeowner who measures fourteen times, posts questions to a forum, and then sands his shims to get it just right. Doesn't make them hacks.
David Meiland Posted June 28, 2013 Report Posted June 28, 2013 Centerline of cooktop/range has to be known early in the process. There is always a range hood centered above or a downdraft below, and there is a gas line and a couple of electrical boxes, so the builder would have been asked early where the cooktop was going, along with many other precise placements that go into a kitchen layout. That's a big screw-up. My guess is that the plumber never installed one before, and didn't know they had a long reach, so he installed it over the burner... although not high enough to fill a large pot.
kurt Posted June 28, 2013 Report Posted June 28, 2013 Exactly. Lateral location doesn't mean too much; it can kinda be anywhere in the working space of the range. But, it's gotta be high enough to fill the big stock pots; that's what it's for. We set them just shy of 5' off the subfloor.
