walterb Posted June 19, 2013 Report Posted June 19, 2013 Help. I need to know the tonnage of a Chrysler airtemp condenser. Only info I can find is comp # 3002-10 and model of condenser 1263-01Q
inspector57 Posted June 21, 2013 Report Posted June 21, 2013 Chrysler Air Temp Capacity: Rating in tons found in the fourth and fifth digits of the model number 0 = 1 ?1.5 ton 2 = 2 ton 3 = 2.5 ton 4 = 3 ton 5 = 4 ton 6 = 5 ton Example: xx06xxxx = 5 ton Googled Chrysler Air Temp model numbers and found this. Accordingly it appears to be a 7.5 ton.... but I doubt that unless you are looking at a commercial system.
walterb Posted June 21, 2013 Author Report Posted June 21, 2013 Thanks Jim but this is definitely a 7 1/2 ton. All it feeds is a large bedroom and small bathroom. Additional info is that compressor is rated at 22 amps.
walterb Posted June 21, 2013 Author Report Posted June 21, 2013 Sorry, I meant definitely not a 7 1/2 ton.
Marc Posted June 21, 2013 Report Posted June 21, 2013 Thanks Jim but this is definitely a 7 1/2 ton. All it feeds is a large bedroom and small bathroom. Additional info is that compressor is rated at 22 amps. 120 volts or 240 volts? Marc
Marc Posted June 21, 2013 Report Posted June 21, 2013 220 volts. I'm guessing 1 1/2 to 2 1/2 tons. I've tried to account for today's air conditioning efficiency resulting mostly from coil design, not the compressor.
walterb Posted June 21, 2013 Author Report Posted June 21, 2013 That would have been my guess also but its nice to get others opinions. Thanks.
tplnc Posted March 5, 2019 Report Posted March 5, 2019 Chrysler Airtemp compressor model # 3005-03R, has 0057 under model #. What tonage is this? This is a 3 phase 230V 60HZ. Part# on compressor is 2012676.
