Ben H Posted June 15, 2013 Report Posted June 15, 2013 Does it exist? Got a DIY basement job and can only see a few inches of pipe. I've only seen almond color, but wanted to make sure.
John Dirks Jr Posted June 15, 2013 Report Posted June 15, 2013 PVC can be used for main supply or for cold distribution lines. PVC should not be used for hot water distribution. Before you call anything out, just make sure what the application is. To clarify, it is acceptable to use PVC on cold distribution lines and main supply lines.
Marc Posted June 15, 2013 Report Posted June 15, 2013 PVC can be used for main supply or for cold distribution lines. PVC should not be used for hot water distribution. Before you call anything out, just make sure what the application is. To clarify, it is acceptable to use PVC on cold distribution lines and main supply lines. In Kentucky? PVC isn't allowed in some states for fresh water distribution, including Louisiana. 611.2 Materials Above Ground.Materials for water distribution and tubing shall be brass, copper water tube. minimum type L, stainless steel water tube minimum Grade H, cast iron pressure pipe, ductile-iron, galvanized steel, chlorinated polyvinyl chloride * (CPVC) or cross-linked polyethylene (PEX) plastic pipe or tubing, all to be installed with approved fittings... Anyway, to answer Ben...I've never seen CPVC plumbing pipe that was anything but almond. Marc
Stephen Lagueux Posted June 15, 2013 Report Posted June 15, 2013 I've never seen white CPVC, they're all cream in color as far as I know. I've seen white peix tubing though.
Erby Posted June 15, 2013 Report Posted June 15, 2013 Might want to check the newest Kentucky Plumbing Code. 2013 Kentucky Plumbing Code
