I can understand why smoke pipes are installed with the male end pointing downward so that creosote runs down inside the pipe but, would'nt poorly fit installations create risk of smoke or other combustion gas to seep inside the house?
The pipe is under negative vent pressure so it would tend to suck room air into the chimney. If the room is more negative than the chimney, shut it down immediately as you have a major problem on your hand.
HTH
Right. The old wood-burning cookstoves would smoke like hill sometimes until the pipes were warmed up. There were gaps everywhere, the firebox, the lids, the seams between all the cast iron plates. The tin pipes would have gaps at all the seams too.
Once you got the thing hot, no more smoke, unless something was burning on top of the stove. [:)]
There was a damper you could close to direct the smoke around the oven and out the bottom. The stove had to be warmed up first.
The direction of the joints will have no effect on whether or not smoke or gases leak out of them.
