After a little research there are flex b-vents out there that can be used. I just have never seen or heard of one, and intuitively I think they are a bad idea. Too easy to get deformed , or smashed turning a two walled vent into a one wall vent... Should have researched more before posting, thanks though.
flex b-vent
Flexible vent connectors are much stiffer than aluminum chimney liner or dryer venting you may be comparing it to. They must be stiff enough to maintain their position including the 1" clearance to combustibles. the fittings on each end are listed.
Any more pics showing that WH connection?
