As I understand it, a furance can be located in a bedroom closet if sole source of combustion air is from exterior. If that isn't the case, what *bad* things could happen?
I always though if there was a CO problem with the furnace, a sleeping chap might not be able to react to the first signs of CO poisoning; they may simply never wake up. This would seem to be the case even if outside air is the sole source for furnace combustion.
"Combustion and dilution air", and it's gotta have a weatherstripped and self closing door.
So, it's a sealed closet too. Can't just be stuffed in a regular closet.
What can happen? A lot, if equipment is installed improperly and combustion air is inadequate.
Inspected a home this week with a small laundry/mechanical area.
This room connected a bathroom/bedroom and the kitchen and in it was an 80% furnace, gas fired water heater and a clothes dryer.
All this and no combustion air!
I indicated to call a heating contractor to have a combustion air inlet installed and to get the CO monitor off the ceiling to a lower point in the sleeping area of the house.
In winter months, here in Michigan anyway, windows are closed and a furnace in an area where it can't get enough combustion air can back draft and cause real problems. Least of all, inefficient operation.
