Input line to the toilet is possibly from the "hot water circuit".
Was the water in the tank warm?
I had a new home construction once that had 3/4 of all hot/cold lines reversed and I could have steamed hot dogs in the toilet tanks.
I never knew there is a little ball in there. I thought it was just a cross cut diaphragm at the opening. And it probably has a hot water feed. I never felt the tank.
It's a dilectric nipple that's got a little marble in it to stop convective flow out of the water heater; it's supposed to reduce heat loss and therefore improve efficiency.
Huh? Got a diagram of that?
35.83 KB
35.72 KB
32.19 KB
There's one's with diaphragms too. Google "heat trap diagrams"; there's about a thousand pics.
37.68 KB
So why does the noise only occur when a toilet is flushed, but not when water is run elsewhere?
The alignment of the stars. The toilet fill valve pulls just enough water to affect the pressure at the heat trap. You probably could reproduce the sound if you messed about with other fixtures long enough.
Humm, I have been needing a idea for some new plumbing questions on the NHIE! We have a question writing session soon.
That IMO is a pretty tough question to be putting on an exam, considering that many of us have never and may never encounter one of those gizmos in our entire careers.
However, if it is one of those choose the best answer out of 4 questions, some of us could guess or deduce the right answer. Maybe that makes it a good exam question.
