Jerry Simon Posted May 1, 2013 Report Posted May 1, 2013 Use of a toggle-switch for such is a no-no, ain't it? Shouldn't it be a timer-type?
Jerry Simon Posted May 1, 2013 Author Report Posted May 1, 2013 What kind of appliance is this? Marc Whirlpool tub motor (sorry, in subject line).
Brandon Whitmore Posted May 2, 2013 Report Posted May 2, 2013 They use those push button air pressure switches w/ no timer all of the time, so I don't see why you'd have to have the timer switch. Code wise, I don't know, because I don't think I've ever seen a snap/toggle switched used.
Eric B Posted May 2, 2013 Report Posted May 2, 2013 The tubs should be on a timer for safety / health reasons. Timers will generally run for 15-20 minutes. The agitation of the water can quickly raise body temperature and with some people this can be a particularly dangerous situation. The other concern with these tubs is bacteria which can flourish in the water lines. The CDC has plenty of info on this.
Scottpat Posted May 2, 2013 Report Posted May 2, 2013 Other than it being GFCI protected I don't know of any other electrical or switching requirement. I see them all the time with a simple wall switch or just the air button on the tub that you mash.
Erby Posted May 2, 2013 Report Posted May 2, 2013 The installation instructions I've seen don't call for a wall switch at all, just GFCI, bonding and the push button air switch, though i often seen toggle and timer switches installed.
ghentjr Posted May 2, 2013 Report Posted May 2, 2013 Mine is a Kohler, GFI protected with a wall mounted timer and off/on push button switch, (mini voltage, not air operated) all supplied by Kohler. Most of these timers have a time limit, mine is 19 minutes. The switch is outside the tub and was designed to be out of reach from inside the tub so you could not keep running it over and over. From experience with my tub I think a timer is a good suggestion as the jets can bruise. "You should keep hot tub water below 40 degrees Celsius to avoid burns or overheating. Most hot tub manufacturers suggest a time limit of 20 minutes per hot tub session. If the water is over 40 degrees C or if individuals remain in the hot tub for more than 20 minutes, users increase their risk of heat-related illness and injury, including heart attack, stroke and brain damage. Pregnant women should not use hot tubs because the delicate fetal brain is subject to damage or injury if exposed to prolonged periods of increased heat. Young children and babies are also at increased risk for heat-related injury or illnesses caused by dehydration."
Jim Katen Posted May 3, 2013 Report Posted May 3, 2013 Mine is a Kohler, GFI protected with a wall mounted timer and off/on push button switch, (mini voltage, not air operated) all supplied by Kohler. Most of these timers have a time limit, mine is 19 minutes. The switch is outside the tub and was designed to be out of reach from inside the tub so you could not keep running it over and over. From experience with my tub I think a timer is a good suggestion as the jets can bruise. "You should keep hot tub water below 40 degrees Celsius to avoid burns or overheating. Most hot tub manufacturers suggest a time limit of 20 minutes per hot tub session. If the water is over 40 degrees C or if individuals remain in the hot tub for more than 20 minutes, users increase their risk of heat-related illness and injury, including heart attack, stroke and brain damage. Pregnant women should not use hot tubs because the delicate fetal brain is subject to damage or injury if exposed to prolonged periods of increased heat. Young children and babies are also at increased risk for heat-related injury or illnesses caused by dehydration." Not to mention causing low sperm counts in men. . .
