Celebrating its 100th birthday on April Fool's Day. What is it?
It looks like you would heat it up on the woodstove and use it to put a perfect curve on the beak of a felt baseball cap. But it is a little too narrow for that.
For curving the blade of a hockey stick? The Vancouver Canucks are celebrating 100 years this year as well.
42.49?KB
43.51?KB
49.48?KB
44.79 KB
How about this hammer? Anybody know what it was used for? Nailing planks on a clinker boat, maybe?
34.57?KB
29.67?KB
The first item was a device for an old method of patching tire inner tubes. The side with the bowl of spikes would have something flammable - I don't know what - and the heat would conduct to the patch and tube, clamped on the other side.
If related, I'm guessing the hammer thing was for removing and seating tires to rims.
Thanks, Bill. I suppose the curve helped to get the rubber to lay flat. The rubber would have been real latex rubber from a South American tree. So that would explain the need for heat.
That also explains the extra corrosion in the cavity part. Maybe gasoline with a bit of motor oil added would work for that, on the side of the road, miles from nowhere.
I hadn't connected the two items before today. I brought the patch melding (vulcanizer?) tool in from the shed and then remembered the mystery hammer as I was posting.
I do remember watching the process of beating a truck tire onto a rim, but that required a big sledge. Thin Model T tires, sure, the smaller hammer could do it.
