paulmars Posted February 19, 2013 Report Posted February 19, 2013 I had to move the tank 3 feet further down towards ground. So, now the heater pump needs to pull fuel up 3 more feet. There was already a long distance from tank to pump. About 40 feet. The tank was at the same height as the pump. fuel got pulled up about 5 feet, over about 30, then down about 5 feet. Its been working like this for 26 years. However, I had to move tank down 3 feet. So, its now pulling up 8 feet, then over 30 feet, then down 5 feet. However, now it keeps cavitating. What to do? Last resort is to move the tank back up. Someone said a small low pressure automotive fuel pump mounted at the tank to push the fuel. This work? tks,pa
Jim Katen Posted February 19, 2013 Report Posted February 19, 2013 I had to move the tank 3 feet further down towards ground. So, now the heater pump needs to pull fuel up 3 more feet. There was already a long distance from tank to pump. About 40 feet. The tank was at the same height as the pump. fuel got pulled up about 5 feet, over about 30, then down about 5 feet. Its been working like this for 26 years. However, I had to move tank down 3 feet. So, its now pulling up 8 feet, then over 30 feet, then down 5 feet. However, now it keeps cavitating. What to do? Last resort is to move the tank back up. Someone said a small low pressure automotive fuel pump mounted at the tank to push the fuel. This work? tks,pa You have a leak in your line somewhere. Have you ever heard of a Tiger Loop?
Bill Kibbel Posted February 19, 2013 Report Posted February 19, 2013 If the tubing is 3/8", it's beyond the allowable line length for an 8' lift. I would be converting to a 2-line system.
paulmars Posted February 19, 2013 Author Report Posted February 19, 2013 1/2" Im considering a tigerloop
