Chad Fabry Posted December 20, 2012 Report Posted December 20, 2012 I'm in the market for vintage ceramic (about 60) two-button switches and un-restored brass cover plates. I also need 7 three-way and 2 four-way. I'm not as fussy about mother of pearl button caps. Anyone?
ericwlewis Posted December 20, 2012 Report Posted December 20, 2012 I'm assuming you saw these and don't want plastic... http://www.houseofantiquehardware.com/p ... ton-switch
emalernee Posted December 20, 2012 Report Posted December 20, 2012 Chad, Try this company. http://www.houseofantiquehardware.com/p ... ton-switch
Bill Kibbel Posted December 20, 2012 Report Posted December 20, 2012 I recommend reproductions. Kyle, the switchplate artist, carries quite an assortment of them. Google Kyle Designs. If you need original, try Ohmega Salvage.
Tom Raymond Posted December 20, 2012 Report Posted December 20, 2012 These are some nice repro's, but they're not cheap. http://www.rejuvenation.com/search?q=tw ... n+switches
Les Posted December 20, 2012 Report Posted December 20, 2012 I've got maybe 6-7 of single pole and maybe 6-8covers out in the barn - somewhere. You need some real numbers. good luck!
John Kogel Posted December 20, 2012 Report Posted December 20, 2012 Saw one in a bucket at Sid's Salvage the other day. I wouldn't want to rely on old used stock, tho.
Chad Fabry Posted December 20, 2012 Author Report Posted December 20, 2012 Thanks, guys. I had some repros and they sucked. I have several old switches that have been in daily use for 95 years. I figured I'd try some used switches. Kibbel's link to Kyle's looks promising- the switch buttons look exactly like the originals I have and the bodies look nicer than the repros that are failing. At $14 a switch, I'll do a room or two a month
Austin023 Posted December 29, 2012 Report Posted December 29, 2012 I have had very good luck finding decent used/vintage and even NOS on eBay....usually they run about $10-15 each and often you can find a bunch being sold in a lot for good prices. I totally agree that the old ones from the 1910s and 20s were made much better than the expensive reproductions. One of the push button switches I found in my travels (still in great working condition with mother of pearl buttons) was removed from a house built circa 1905 during rewiring, with a patent date of Aug 30, 1897. The good ones have all-ceramic housings, not Bakelite or other plastics. You can even find those "turn" switches occasionally on there as well (not the surface mount type, but the type that goes in a standard device box in the wall and has a brass plate with one hole for the knob); those are quite interesting if you can get a hold of one--though they command rather high prices of $35 or more usually.
Austin023 Posted December 29, 2012 Report Posted December 29, 2012 I also wanted to include that the old ceramic switches are pretty easy to inspect internally & clean out/repair if needed and so desired. I always check the contacts inside them to make sure they are still nice and tight and free of dust/debris--and I slightly oil the mechanism if needed. Only if the rocker inside or the ceramic housing is broken are you really out of luck with these....they were made to literally last a lifetime.
Norcal Posted January 14, 2013 Report Posted January 14, 2013 Some Asian import reproduction switches are rather cheesy in construction, the terminal screws are tiny & most suitable for 16 AWG conductors, maybe 14 AWG, the vintage ones are quite robust in comparison.
Tom Raymond Posted January 14, 2013 Report Posted January 14, 2013 These were at yesterdays inspection. Click to Enlarge 68.94 KB I liked these better. Click to Enlarge 51.27 KB This gig was postponed twice because after the seller accepted an offer she decided she wanted to keep the light fixtures. Click to Enlarge 30.44 KB Click to Enlarge 40.47 KB Click to Enlarge 36.12 KB I don't normally do inspections at noon on Sunday, at least there were snacks... Click to Enlarge 41.37 KB ...dill pickles from 1956. There were all kinds of preserves but the pickles were the most, well, photogenic.
Chad Fabry Posted January 14, 2013 Author Report Posted January 14, 2013 Nice lights. We were fortunate; our house had most of its original fixtures from 1926.
