Jerry Simon Posted November 29, 2012 Report Posted November 29, 2012 Same was very noticable as we looked up from the ground on this ten-year-old roof, and I explained to the client the roof decking may not have been installed with adequate panel spacing, and/or without h-clips. In the attic, both items were (weren't?) observed; no spacing, no clips. It's a ten-year-old asphalt shingle roof covering, and aside from the cosmetics, I don't see where the buckling has posed or may pose a problem. What say yee all? How would you report? (OSB, by the by.)
Marc Posted November 30, 2012 Report Posted November 30, 2012 7/16" rated sheathing on rafters 2' on centers? Marc
Jim Katen Posted November 30, 2012 Report Posted November 30, 2012 Same was very noticable as we looked up from the ground on this ten-year-old roof, and I explained to the client the roof decking may not have been installed with adequate panel spacing, and/or without h-clips. In the attic, both items were (weren't?) observed; no spacing, no clips. It's a ten-year-old asphalt shingle roof covering, and aside from the cosmetics, I don't see where the buckling has posed or may pose a problem. What say yee all? How would you report? (OSB, by the by.) I'd recommend fixing the sheathing when they replace the shingles. It makes little sense to do it before that.
Tom Raymond Posted November 30, 2012 Report Posted November 30, 2012 It's a 10 year old asphalt cover. It's either at or passed the mid point of it's service life. Unless you observed significant damage from the attic, the OSB should last at least as long as the cover. FWIW, an installed asphalt roof goes for $4-600 a square. Replacing the sheathing will probably add another $200 a square. That is a major expense they'll need to budget for in the next 5-10 years. Probably enough to make some walk.
Phillip Posted December 2, 2012 Report Posted December 2, 2012 I have found a few places where the roof decking that bucked up had torn the felt paper and water was getting in. I wish I could find that photo. I was there when it was raining.
