Jerry Simon Posted November 21, 2012 Report Posted November 21, 2012 How does one test such using this thermostat? Click to Enlarge 7.34 KB
Robert Jones Posted November 21, 2012 Report Posted November 21, 2012 I have the same one. It is more than likely set on a schedule. Here is the user manual. The floor was already warm in that pic. The temp when on the "set" schedule, goes from 64-82 degrees. Of course the home owner could have adjusted the settings. http://www.aubetech.com/manuel/2/TH115- ... 4T-15S.pdf
John Kogel Posted November 21, 2012 Report Posted November 21, 2012 If I saw that, 77 degrees F, already too warm, I would check the temp with my laser thermometer, then switch the toggle switch off, switch on the upper left. I leave the thermometer or a biz card laying there to remind me to change it back later. Check the heat in about an hour, should be cooler, turn it back on, check again at the end. If there are up and down arrow buttons, you can run the heat up or down a few degrees, and, yes, I hate messing with programs too.
hausdok Posted November 21, 2012 Report Posted November 21, 2012 Just use the mode button to switch it to manual mode (It displays a hand with a pointed finger) and run it up 7 degrees over room temperature to get it to come on. Make a mental note of the temperature and then dome back in a little while and feel the tile to see if it is getting warm and check the stat to see if it's going up. Let it go up a couple of more degrees just to confirm and then switch it back to program mode and it will return to the owner's settings and the heat will shut off. Come back a little later to confirm that the temp is dropping. Pretty simple really. ONE TEAM - ONE FIGHT!!! Mike
kurt Posted November 21, 2012 Report Posted November 21, 2012 That's what I do. I hit it with an ir image for show.
